Connecting an Oil furnace to coal furnace
I have an existing Buderus oil fired hot water baseboard system in my house. I would like to pipe a Keystoker KA6 boiler in series with the existing system. I was hoping to find a diagram or pics of how it has been done. I’d like to keep the existing system when I will not be able to feed the coal system when I’m out of town etc. Any thoughts, info or pics would be appreciated. Thanks
You don't want them in series...
https://www.caleffi.com/sites/default/files/coll_attach_file/idronics_10_0.pdfThere was an error rendering this rich post.
I don't want the systems to run together. I want the coal to heat the water and the static oil to move it0
You -- an the boilers -- will be much happier if you pipe them in parallel, each with their own circulating pump and valving, with the rest of the system piped primary/secondary in the usual way. There are several ways to control such a setup. It can be fully automatic, or you can have manual switchover.Br. Jamie, osb
- 15.8K Strictly Steam
