Homart 775.8816
ksd99
ksd99 Member Posts: 78
edited January 2019 in THE MAIN WALL
I am changing out some vents on my radiators for my 1pipe steam system , can I use a Dole 1933 in place of the Homart 775.8816. The Homart appears to be a bit longer.
New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.
    Steamhead Member Posts: 18,495
    This is a steam system, correct?
    Consulting
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    If it is a steam system, then we like the Big Mouth, which is good for 50 feet of 2 inch pipe, at very low pressures, (1.5 psi, or lower for economy).
    Is your system a small household system?—NBC
  • ksd99
    I have a 1 pipe steam system. I am not sure what you mean by a small household system, but my home is 350o sqft.
  • ksd99
    I should also clarify I am changing a vent on radiator
    Are you having some problems which would indicate a lack of venting?
    First verify your main vents to be working, and adequate, then check your radiator vents.
    Use slower vents on the radiators, and fast ones on the mains.—NBC
