Steam Radiator single pipe air venting rusty smell
Thanks @ImYoungxD,
I'll try to calibrate it using this method.0 -
When you get your 0-3 psi gauge on, you can see the pressure come up to near what the P-troll is adjusted for. Then you can realize what is cycling the boiler burner.
If I understand correctly the Safeguard will not cut out the burner until a true low water condition, whereas the Cycleguard will stop the burner and check the water level then restart the burner.
What does it say on the front of the LWCO?0
- 116 Geothermal
- 169 Indoor-Air Quality
