W.M. Sharf Pat. Jan.11.1910 Coal Ash Carousel Pit for Boiler Operations
so thats what the inards look like.
this is one i found a month or two ago
So you could apparently choose how many bins were in the carousel, makes you wonder how few or many.0
I am quite sure this is what is in the basement of our house. We have been wondering for years. It has six segments. I got to this page by entering the patent date but I can find no other information.
The cleverness of our ancestors continually amazes me.0
So I'm curious. Where would the boiler or furnace be located in relation to the ash pit? Nearby no doubt? Not on.top though I guess. Would you sweep or push the ash into the pit?
So this is just for ash storage? Once all the bins are full, you would have to either remove them and dump, or shovel them out?
I know from those who burn coal that the volume of ash is huge!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I guess it turned a daily or weekly routine into a weekly or monthly routine.0
Maybe your coal service would come and empty them, and they and you would rather they come less often.
Not sure the size and weight of the bins when full of ash but they look awfully heavy and awkward for one or two people to lift up out from under the basement floor. Am thinking there has to be another piece of equipment that went along with this system that would lift those bins out of the carousel. I am I correct someone would shovel the ash in the bins or was there some type of mechanical feeder?0
Back in the late 70's while in college (Philadelphia main line) I was a "house sitter" . I had a couple of them -- biggest was one owned by the granddaughter of old coal/oil money. The original steam plant had a floor bin contraptions to clean out the boilers. The space for the coal was huge -- big screw contraption to feed the beast ... full time staff that lived in the building. All natural gas by the time I came around. The dust must have been everywhere --- with 60 acres they had the luxury of space and it's own driveway. The ash eventually went to a lower level.
I wonder if the bin was to insure the ash was no longer hot and not a fire hazard? Since it had many spaces -- it would take time before one space made it around and dumped it to the next level for removal.
Oil must have taken over after WW1 -- Another was one of the first developments in Gladwyne PA (3 houses) .... about 10 acres each .. the one I watched had 35 odd rooms. Huge oil boilers still in the boiler rooms. Again -- replaced with natural gas.0 -
I'm awfully late to this discussion. Our home was built in 1920 in an urban area. We moved in 2014 and I always wondered what was under the odd-shaped access cover which didn't interest our pre-closing home 'inspector' at all. Noticed a bit of condensation near the access on a plastic tub one day and opened it up to find a perfectly still and full round pool of water! No one locally seemed to know what it was and fearing it could devalue the house or be required to remove I quit asking around. There seemed to be a slight 'oil' feel to the water so one guess was a separation system to keep oil from an oil fired boiler from mixing into the city water? Rain water was slowly filling the basin as the subfloor tiles were in poor shape. It lived its second life as a catchment I guess!
Finally had to dig up the floor for storm water drainage purposes and was able to decipher the markings on what I thought were a floor drain…this led me to this page. How interesting! I can't imagine that the original boiler used coal for too many years. Where did they get rid of all that ash here in the city?
Our round basin perimeter (cast iron) is in good shape but the baskets have all pretty much crumbled. Not sure what they were made of? The crank circle with the numbered markings was replaced with a simple drain cap at some point but the spindle workings and basket supports are still in place and finally visible.
Will be filling this basin in with clay/earth and broken concrete and stone over perforated drain pipe with sock filter then cement. One less of these in this world!
In case anyone is interested in Mr SHARPS patent…
Having .pdf issues.. will try pics
Tried adding a .pdf and got a network error using the paperclip "attach" .. used the picture import and got these stretched pics when I posted.. preview looks good 🤷♂️
One way to get familiar something you know nothing about is to ask a really smart person a really stupid question1
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
