flow in fin tube baseboard heat
mdwdrw69
Member Posts: 1
Does running more than 4gpm in a standard high output fin tube base have any effect on the maximum output
Or is the maximum achieved at 4 gpm and anything faster just stays capped at the maximum output
The only thing changing flow rate will do -- within reason, that is -- is change the delta T across the radiation. In principle, a smaller delta T, for a given input temperature, will give slightly higher output, since it is the average of the input and output temperatures which determine the output.Br. Jamie, osb
plus velocity wear and noise at high flow ratesBob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
