Steam System not pressuring up
DIYSteam
Member Posts: 12
I replaced almost all the steam traps for the radiators in my house. There’s like 4 left in the house. Those radiators heat but not super hot. Is it possible those traps leak and that’s why I am not seeing any pressure build up? I installed a brand new low pressure gauge and to test it I plugged off the main line vents for a short period to see if I would then build pressure and I did. After unplugging the pressure went back down and has not increased since. The boiler runs until the thermostat is satisfied. The cutout pressure is never achieved.
You don’t want pressure. Building pressure means you are heating less efficiently.1
Yup your fine
Many on this site like low pressure gages and low pressure controls (vapor stats)
Their fine
But
In a house home heating system you do NOT want to build steam pressure. If your boiler runs and heats the house and builds no steam and vents quickly that is a perfect system. You don't need pressure. You can put a low pressure gage on the boiler if you want add it to the 0-30 psi gage you have and make sure your pigtails on the pressure control and gage are clean.
Never mind the pressure unless it's too high. You need to decide if your house is heating evenly and then go from their
There is too muck talk about building pressure. It leads many to think there is something wrong if they don't have pressure.3 -
KC and Ed thanks so much!0
- 50 Industry Classes
