Pipe bath after the machine thread?
GW
Member Posts: 5,134
We generally just wipe the pipe and try and get some rag material inside the pipe after we thread. Anyone have a concoction to dunk their new thread into a bucket of cleaner solution? CLR?
Some piping added to an old steamer with no port for skimming. I used a 5 gallon bucket with hot water and Dawn DW detergent. Even brushed the inside. Then rinse well with hot water. I used the DHW drain valve for hot water source.
They get the bonus of flushing the bottom of the tank....otherwise it would never get done.0 -
At the Steam Dream Team job we used Brake Kleen after it was threaded followed by a wipe and then dunked in soapy water. That seemed to really clean off a lot of the oil.
We also only used the Ridgid spray oil, seemed to do well. And yeah I knocked over the oil pan so that may have something to do with it
Peter Owens
SteamIQ0 -
Green can CRC brake cleaner if I'm not near any plastics. The green "50 state" formula is essentially acetone in a spray can, and will destroy plastics. Red can when I'm near plastics but not high temps. It's essentially chlorinated dry cleaning solvent. (Red can + fire/high temps = Bad, bad things, Phosgene included.)0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
