KenTr Unions in tank fill & vent piping
KenTr
Member Posts: 1
in Oil Heating
I am thinking of replacing my 275 oil tank in my basement. Its is 40 years old and stating to look a little shaky at the bottom, I am thinking off cutting the fill and vent pipe in the basement to remove the tank. I would then install a pipe union at the cut point to install new tank. I am not sure this is permitted by code. I am trying to avoid removing all the piping to the outside. It is a lot of digging and the ground is frozen. I live in SE Pennsylvania ( Avondale). Input would be appreciated
Check with your oil company and your authority having jurisdiction -- building inspector or fire marshall or both -- as requirements vary.Br. Jamie, osb
Correct installation is extremely important, most people just chuck them in, the vent has to be higher than the fill, the fill should be on the opposite end from the filter and the filter outlet should be the low point so that you can flush any water and contaminants out.0
