Candles and CO
kcopp
Member Posts: 4,682
Anyone ever run into a situation where scented candles set off a CO detector? Son lives in a place where the CO detector will register 10 ppm and then one time 42.
Has Gas FHA heat.
Tech came out out found nothing.
He has taken my Testo out 2 times and nothing....
The candles came up in a passing conversation....
Has Gas FHA heat.
I never checked with an analyzer or meter but have to assume it's entirely probable.
Anything else (chemicals) possible giving a false reading to cheaper CO detectors?There was an error rendering this rich post.
I will ask.
They have 2 detectors. 1 up, 1 down. The upstairs has never gone off....no candle(s) up there either.0 -
There is no reason why a candle wouldn't produce some CO. Uncontrolled combustion of carbon containing compounds. Ditto wood fires. The question is -- is it enough to worry about? You should be able to measure it, given a sensitive enough detector in the updraught from the candle, but... really now...
Suppose it depends on size, number of candles, and how long you burn them. Plus size and how tight the room is.
PBS TV show "queen VICTORIA", ~ 1840's , shows 20-300+ candles burning. But they also had fireplaces, that acted as LARGE exhaust fans.
For mosquito control outside I make my own LARGE candles, burns with 1 inch wide by 2- 4 inch tall flame. I burn 2 or 3 of them outside in the yard. Helps a lot, just regular wax ( old 1/2 used scented candles people throw out)
To make them.....I take a 1 foot diameter glass salad bowl, put in a wick made of kitchen paper towel , folded to ~ 1"x 1/8" cross section, then add chucks of wax from old candles , then melt in extra wax with propane torch to fill the spaces between chunks.
Makes me wonder how much CO those old kerosene lamps with 1 inch wide wicks made. I've used a few outside at nightime dinners.0 -
Just kind of curious... where do you find "old 1/2 used scented candles people throw out" ?Leonard said:For mosquito control outside I make my own LARGE candles, burns with 1 inch wide by 2- 4 inch tall flame. I burn 2 or 3 of them outside in the yard. Helps a lot, just regular wax ( old 1/2 used scented candles people throw out)
Here in a BIG city 100k+.....When the economy was better people used to throw out a lot of GOOD stuff on the curb on trashdays. Or when they moved in springtime ( didn't want to pack it all up). Usually only find 2-6 jars at a time, but twice found box full of them. Or shoebox full of 1/2 burnt candle sticks. Even once few cardboard boxes of big chunks of attic melted new raw wax slabs. Craigslist free ads too.
Also some goofy scented candles that people didn't like..... but it's all fuel for outside use. I put them 10 ft from me when I'm working on the car and get few mosquitoes and no smell.
Especially in richer areas, or high rent apt complexs, working electronics too. Got my fancy wide screen Sony TVS , Audio amp, speakers, TIVO, DVD player, MW, VCRs that way. 10 hp Snowblowers needed a little work. Computers for parts or use. Took a few years to accumulate all of it. Amazing what rich people throw way.
Instead of expensive torch lamp oil, some #2 heating oil works too, I cut it with with ~ 1/3 old gasoline to increase flamability and stop the 3 inch long oily soot threads. ( YES ... I do test for no match flamability of liquid mix for safety)0 -
During tropical storm Sandy some years ago, the power went out for 6 1/2 days here. It got mighty cold. That was what inspired me to get a backup generator.
I lit 6 or 8 candles in my bedroom and shut the door. After an hour or so, the temperature of the room even went up a degree or two. But my high sensitivity CO detector alarmed at 7 ppm or about that.
I do not suppose that was a false reading. I did not open any windows, but I did extinguish most of the candles. (I would never leave them burning when I was asleep.)0 -
kcopp, I don't know about the specific composition of the scented candles giving bogus reading on a CO meter, but I would not discount it. Some of the chemical released might "look like" CO to what ever sensor the meter is using. Tim seems to have some specific knowledge. It would be nice to have a source. Experimentation is sometimes easier. Just burn some scented candles and unscented ones under the same conditions. Try to match the extent of flame as well as you can. See what your meter says.1
- 120 Geothermal
