Condonsate Receiver
bean
bean Member Posts: 34
Does my steam system need a condonsate receiver at the boiler ? How would I know?
    Jamie Hall Member Posts: 27,377
    How long is a string? We would need a lot more information about your system to come up with any kind of answer to that one -- though one can say that, in general, a residential system, properly piped, vented and trapped, does not need one.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    Has someone told you that you need one? Only in some extreme situations would one be needed. It adds some unnecessary complication, and possibilities for a later breakdown, so when it's not needed, it's best to pipe the boiler as a gravity return system.
    Modern boilers are designed to have enough water content to fill all the pipes and radiators. There are other ways of using a non-powered reservoir tank, in the unlikely event more water is needed.--NBC
