IBC DC20-125 boiler making noise on LP
DickC
Member Posts: 15
in Gas Heating
Has anyone run into an issue with this boiler making a howling noise on LP? In for two weeks and can't seem to solve the issue.
If your installer is having difficulty w/ this he should call IBC and talk to one of the tech guys. Depending on where you are a IBC rep could even go out... Where are you located?0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
