flat radiator, single pipe system
Dan_43
Member Posts: 53
I want to move a radiator to a spot that I only have about 2" of depth. Is there a flat radiator for a single pipe system?
Dan
Dan
Nope.All Steamed Up, Inc.
Consulting0 -
I appreciate your straight forward answer!
Could I build a radiator out of 1-1/2" black pipe, close nipples, Tees and elbows? this configuration would be orientated vertically with a tapped vent at the end of this contraption. Size would be based on matching the EDR of the existing radiator.
Dan0 -
Http://www.steamradiator.com, these are fairly flat. The minimum depth the “steamview” can be adjusted to it 2.5”.0
They still need to stand off of the wall at least a couple inches.0
just don't scrap the old rad keep it in the basement if you or someone else in the future wants to put it backI just earned my GED and am looking for a apprenticeship with one of these steam gurus on this site!0
Most of mine are within 1” of the wall. A few within a 1/2”. Not ideal, but don’t see an issue. Even a 1/8” air gap I have on one radiator is enough to prevent the wall from getting too hot.Fred said:They still need to stand off of the wall at least a couple inches.
I'm not concerned about the wall getting to hot. Radiators need enough air movement around and behind them for proper convection.mikeg2015 said:
@Fred, the steam view is designed to be at a minimum overall depth of 2.5”, 1.9” to center of rad.0
The depth off the wall has to do with convection.Retired and loving it.0
So if the rad is too big? I theorize that ideal heat is all radiation.DanHolohan said:The depth off the wall has to do with convection.
I would think if the rad is too big, it will only partially fill. Blocking convection would seem to me to be less than ideal in that you are preventing full heating potential of the rad.jumper said:
Thanks for all your comments. I understand the need for air flow around the radiator. The issue is that I need to relocate the point in which the heat enters the kitchen. After doing some more calculating in order to get enough EDR with the pipe I would have to have my pipes go to the ceiling! I will have to consider another location. Is it so bad to have a radiator on an interior wall?
Dan1 -
You can have the radiator anywhere you want within the room, @Dan_43. Just make sure the piping going to and from it is done properly.Retired and loving it.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
