Trap or strainer?
Mike_Sheppard
Member Posts: 696
Is this a steam trap or a strainer? It’s on the condensate return just before the feedwater tank. Never seen one like it.
If it’s a trap it’s coming out!
Never stop learning.
1
Photo?
President
HeatingHelp.com0 -
> @Erin Holohan Haskell said:
> Photo?
A photo might help a little... my bad!
Photo added to main postNever stop learning.1 -
Looks an awful lot like a strainer to me... complete with a little drain port to allow flushing out the collected goop.Br. Jamie, osb
@Jamie Hall that’s what I am thinking. But I am not 99% sure. Perhaps I will just take it apart. If it’s a strainer it probably needs to be cleaned and if it’s a master trap it needs to be removed.Never stop learning.0
Someone I know mentioned this may have been a strainer on a vacuum system, and something may have been connected to the top.
Now I’m wondering if it used to be a vacuum system. Is there a way to tell other than counting the EDR and comparing supply/return pipe sizes?
Has anyone ever re-installed a vacuum pump system before?
Edit: Building was built in 1917. Could it have had a mechanical vacuum system?Never stop learning.0 -
looks strainerishto me0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
