Trap or strainer?
Mike_Sheppard
Mike_Sheppard Member Posts: 696
edited January 2019 in THE MAIN WALL
Is this a steam trap or a strainer? It’s on the condensate return just before the feedwater tank. Never seen one like it.
If it’s a trap it’s coming out!
Never stop learning.
Erin Holohan Haskell
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,358
    Photo?
    President
    HeatingHelp.com
  • Mike_Sheppard
    > @Erin Holohan Haskell said:
    > Photo?
    A photo might help a little... my bad!
    Photo added to main post
    Jamie Hall Member Posts: 25,710
    Looks an awful lot like a strainer to me... complete with a little drain port to allow flushing out the collected goop.
  • Mike_Sheppard
    @Jamie Hall that’s what I am thinking. But I am not 99% sure. Perhaps I will just take it apart. If it’s a strainer it probably needs to be cleaned and if it’s a master trap it needs to be removed.
  • Mike_Sheppard
    edited January 2019
    Someone I know mentioned this may have been a strainer on a vacuum system, and something may have been connected to the top.
    Now I’m wondering if it used to be a vacuum system. Is there a way to tell other than counting the EDR and comparing supply/return pipe sizes?
    Has anyone ever re-installed a vacuum pump system before?
    Edit: Building was built in 1917. Could it have had a mechanical vacuum system?
    EBEBRATT-Ed Member Posts: 17,344
    looks strainerishto me
