IBC DC20-125 boiler making noise on LP
DickC
DickC Member Posts: 15
Has anyone run into an issue with this boiler making a howling noise on LP? In for two weeks and can't seem to solve the issue.
  • kcopp
    kcopp Member Posts: 4,675
    It needs to be properly set up. Gas pressure checked and adjusted w/ a combustion analyzer.
    ratio
  • kcopp
    If your installer is having difficulty w/ this he should call IBC and talk to one of the tech guys. Depending on where you are a IBC rep could even go out... Where are you located?
  • kcopp
    @DickC any update on this?
