Help with thermostat for old boiler driven hot water tank
John_141
Member Posts: 54
My brother in law has an older home in Bernardsville nj where the hot water for the the house is done using the houses boiler and a hot water storage tank. It seems that the thermostat for the hot water is not working, no matter the setting on the thermostat the hot water is always scalding. I have a poor shot of just the thermostat, I can get more pics if needed. Is the thermostat replaceable or should I advise my BIL to get a traditional hot water heater?
You need a mixing valve on the domestic side, for starters. And you need a competent tech to check the aquastat and controls for proper, safe operation.
Start with a few pics of the piping around the boiler & tank, enough & of a quality to follow the pipes around visually. Closeups of the controls to show the set points (as you posted earlier) too.0
John_141
A few more pictures would be very helpful. Sounds like you are getting direct boiler water temp. Dangerously hot water coming out of your faucets?
You will need to install a mixing valve to supply those faucets at a safe temperature. Pictures will help to communicate your problem with you.0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
