Finding a pressuretrol
Lakewood
Member Posts: 9
Dan the Great says to have a steam boiler set to 1/2 psi. I am working on a comercial boiler but 5he pressure can't go lower than 2psi. I would like to change it. I looked for one but don't know which one to get. The pressuretroll has to be 120v. Any suggestions?
Your regular supplier should be able to get one, if he doesn't have one -- try State SupplyBr. Jamie, osb
Model number?0
Honeywell PA404A1033. Supply House has them in stock... https://www.supplyhouse.com/Honeywell-PA404A1033-Pressuretrol-1741000-pBr. Jamie, osb
The lowest a pressuretrol will go is 1.5 PSI, to go lower you need a vaporstat.
3PSI gauge0
