Finding a pressuretrol
Dan the Great says to have a steam boiler set to 1/2 psi. I am working on a comercial boiler but 5he pressure can't go lower than 2psi. I would like to change it. I looked for one but don't know which one to get. The pressuretroll has to be 120v. Any suggestions?
    Jamie Hall Member Posts: 27,379
    Your regular supplier should be able to get one, if he doesn't have one -- try State Supply
  • Lakewood
    Lakewood Member Posts: 9
    Model number?
    Honeywell PA404A1033. Supply House has them in stock... https://www.supplyhouse.com/Honeywell-PA404A1033-Pressuretrol-1741000-p
  • BobC
    BobC Member Posts: 5,566
    The lowest a pressuretrol will go is 1.5 PSI, to go lower you need a vaporstat.
    Bob
    3PSI gauge
  • ChrisJ
    ChrisJ Member Posts: 17,391
    Bob
    Is that a 20 PSI Pressuretrol or a 4 PSI Pressuretrol?
