Bang noises after changing Zone Valves
S2kfixit
Member Posts: 1
We had issues with heating and the specialist came and changed all 6 zone valves. After that we hear bang when it turns off it makes a bang noise. This only happened after new valves are installed. Specialist does not have to time to come back as he is very busy and this issue is way down in the list.
Before the zone valve said Automag 3/4-14 and he installed Taco zone valve. don't know if that makes any difference. Any suggestions will greatly be appreciated.
Did the specialist allow any air to get into the system? That could cause banging. If that has happened, you need to bleed the system from the highest locations you can get to.0
Specialist? What was the diagnosis by this expert that all 6 zone valves were bad? I'd call and tell him this is his #1 priority, or you can get it resolved and send him the bill.
Sounds like the zone valves are installed for direction of flow opposite to the flow of the circulator.0
Changed the zone valve having issues and he’s too busy to resolve.
That’s just B $0 -
He changed 6 of them...how bout that? First of all, who carries 6 zone valves on their service truck?pecmsg said:Changed the zone valve having issues and he’s too busy to resolve.
That’s just B $There was an error rendering this rich post.
2 -
A Zone Valve "specialist"STEVEusaPA said:First of all, who carries 6 zone valves on their service truck?
4 -
The old valves were probably heat actuators.
CC company will have your back if that's how you paid. Cancel payment.0 -
The old valves were these https://www.automagzonevalve.net/products.php
If the new ones are zone sentry's, they are not directional.
The hammering can be caused by several things. Dead heading a pump, flow checks in incorrect locations, air in pipes to name a few.
Some pictures of the boiler, zone valves and piping would help."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Auto Mag valves are also d.c. if I remember right. But, they are a solenoid style valve, so you would think they would bang when they close.
Rick0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
