Somebody talk me into buying a Caleffi Pump Cart. Is it worth the dough?
JohnNY
Member Posts: 3,230
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
We love ours and have never regretted that investment . Just do itYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
I don’t have there pump cart but use one a buddy made using 1 inch quick connects with I guess a 30 gallon rectangle tank w a 110 v 1 hp pump w a pool type strainer. The things about 30 years old works great we use them on tube n shell exchangers n Evaps I know they ain’t cheap I would guess his costs w hand truck bout 800 buck to make. He states between that n hoses he s made more money on those investments over any other tools throughout the years peace n good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Thanks, guys. I hope to hear from someone else who bought it.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
I bought one a bunch of years ago and well worth the money. I also built my own for the smaller jobs.-1
@JohnNY if you get it, can I borrow it?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
I've been considering it myself, but it looks overkill for small. residential jobs which is about all I do.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It's actually great for small residential jobs Alan .I've been considering it myself, but it looks overkill for small. residential jobs which is about all I do.
732-751-1560
Rich McGrath 732-581-3833-1 -
Rich: How did the Rehoboth Beach job turn out? You can update us here:
https://forum.heatinghelp.com/discussion/167174/rehoboth-beach-delaware#latest
or email me at berkeleyradiant@gmail.com8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I ended up getting the Rhomar version. A bit smaller and had a magnetic filter w/ it. A lot easier to wheel around.
http://www.rhomarwater.com/Power_Flushers_Filters.html0 -
I've got an older version through Buderus which I think came from the same manufacturer back then. I paid about the same as this one lists for at SupplyHouse.com.
It's great for solar, radiant, SIM, jobs of almost any size.
Mine tops out at about 40 psi; this one appears to go to 100 psi.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
I bought it. Done.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes2 -
Thanks, I'm sure it will serve you well, a nice heavy duty cart and stainless Grundfos pump. Be sure to drain or squirt some RV antifreeze in it if it is in a freezing truck.JohnNY said:I bought it. Done.
Living the hydronic dream1 -
Might I ask if it was more or less costly than the Caleffi? I was looking at those also but can't get a price anywherekcopp said:I ended up getting the Rhomar version. A bit smaller and had a magnetic filter w/ it. A lot easier to wheel around.
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
