Before and After
GW
Member Posts: 5,060
9:34 AM
10:20 Am
3:20 PM
still waiting for the electrician to show up.
More better? Old piping was lamo
10:20 Am
3:20 PM
Thanks the pic angle isn’t too good. There are two return drops, one behind the other. Gorton vents on the better location not the end of mains0
Ahh better is there a simple trick I need to learn?0
What size Uticas before and after? Was the original sized OK?
Love those long risers, DRY THAT STEAM BABY!0
Both 150,000. Utica PEG150. The old system was piped lamely. We jazzed it up1
30 inchers, the Ridgid 300 cranked out 9 pipes for this one0
Sometimes your computer will flip the image for you automatically in the thumbnail viewer, but the file will still be oriented the wrong way. The best way around this is to open the photo in Photo Editor, set the orientation correctly (rotate the photo, if needed), and do a Save As for for the file.GW said:Ahh better is there a simple trick I need to learn?
President
HeatingHelp.com0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
