Steamer and steam main repipe
EzzyT
Member Posts: 1,295
The steam mains, main venting and wet return flushing valves we did a couple of week ago.
The steamer repipe we did today.
Still have to go back to skim some more and wand the hell out to the boiler and flush the wet return.
Also have to down fire the boiler by replacing the burner tray assembly since the boiler can be used with two different fire ratings, and the homeowner now wants to install s automatic water feeder.
Didn’t have any DM filters in stock still waiting for more to come in. Installed a CO detector with a relay that will kill the boiler if the CO detector alarm goes off
2
Great looking job ezzy You cranking it out keep up the great work your a true credit to the craft of steam fitting a true sight for tried eyes. Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
