Dunkirk boiler furnace
tricia
Member Posts: 3
Our boiler unit goes to E53 every time it is windy. We unplug unit and it restarts. Anyone have this problem or have an idea for solution?
Can you tell us the model number of the boiler?—NBC0
Dunkirk dcb 125 is the model0
Can you post some pics of the vent termination on the outside wall and also of the boiler and its near piping?Bob Boan
The control flashes error 53 and if it gets unplugged from outlet and repluged then the system will run it seems to happen on windy days so I wondered if wind going into exhaust pipe is activating the sensors to shut off??0
That is a Baxi I think check to see if you are getting CO back in the intake air that code is flue problem.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
