Dunkirk boiler furnace
tricia
tricia Member Posts: 3
Our boiler unit goes to E53 every time it is windy. We unplug unit and it restarts. Anyone have this problem or have an idea for solution?
  • Can you tell us the model number of the boiler?—NBC
  • tricia
    Dunkirk dcb 125 is the model
  • Ironman
    Ironman Member Posts: 7,827
    Can you post some pics of the vent termination on the outside wall and also of the boiler and its near piping?
    Bob Boan
  • tricia
    The control flashes error 53 and if it gets unplugged from outlet and repluged then the system will run it seems to happen on windy days so I wondered if wind going into exhaust pipe is activating the sensors to shut off??
  • superdave
    superdave Member Posts: 155
    That is a Baxi I think check to see if you are getting CO back in the intake air that code is flue problem.
