Help with steam radiator
BenM21
Member Posts: 4
I live in a co-op building in Queens and the steam radiator in my bedroom makes loud banging noises every night. I keep the radiator off completely as the building is very hot but the noise is always there. I have a feeling it is the intake pipe as it is long and the floor of my bedroom is not level, perhaps water is getting trapped in the pipe and being driven around when hot steam comes in? My super has basically told me to live with the sound, that it is an old building etc. Is there anything I can do on my own to try and remedy this noise? It is really loud and happens 5-10 times a night.
Three things to try... first, open the valve to the radiator. They rarely close completely, and they allow steam by and condensate to build up -- which may bang. Second, if the room is too hot, try turning the vent on the opposite end upside down. Rotate half a turn. That may shut the vent off and reduce the amount of heat from the radiator. Third, there may be a horizontal pipe under the floor. Try lifting the radiator to see if there is any give -- if there is, try raising it at the valve end about half an inch and at the vent end about 3/4 inch and see if that helps.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1 -
Is there some super school where they teach this hogwash, or are they born saying it?NJ Steam Homeowner.
I should have clarified in my first comment but the banging is definitely not coming from the radiator but from the pipe. I've opened the valve and raised the radiator as there is a lot of give. Hopefully this helps0
There may be water in a hoeizontal pipe under the floor. Try lifting both ends of the radiatot up to see if you can get better performance. As I've said before be careful to lift slowly so yopu don't over stress the old plping.
3PSI gauge-1 -
I've tried lifting it and it hasn't made any difference. I'm assuming the only other option is going into the floor and fixing the pitched pipe?0
Before you tear up floors, talk to the neighbor under your apartment and ask them if they hear the banging. It is very possible it is not your radiator or piping that is causing the problem but one under you that is fed off of that same riser. We've seen that happen several times before. Noise will radiate through pipes.3
I will definitely do that, thanks so much for the suggestion!0
Look closely at that valve. It might be a "globe" or "stop" valve instead of a "gate" valve. If so, it's holding water up in the radiator and that's what's causing the banging. We've actually run into cases where the Dead Men made this mistake!All Steamed Up, Inc.
Consulting0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
