Nice and Affordable Low Pressure Gauge
zackwatt
Member Posts: 81
Looks nice and readable, but I couldn’t find it on their site-is there a link?—NBC0
Maybe this one: https://www.zoro.com/zoro-select-press-gauge-low-press-diaphragm-2-12-in-18c794/i/G4739332/
That's it!ethicalpaul said:0 -
Also available with bottom mount:
https://www.zoro.com/zoro-select-press-gauge-low-press-diaphragm-2-12-in-18c778/i/G4739436/0 -
Saw this
"Sign up for Zmail and get 15% off your first order."
It'll be around $22 + $5 shipping-1 -
Does it have an adjustment screw that lets you set it to zero?
Otherwise it looks good other than containing the alloy of Chinasiem.
Are you sure it is for steam? The specs say it it rated for up to 160 degrees.0
Steam or heat won't reach the gauge.iamsteamed said:Are you sure it is for steam? The specs say it it rated for up to 160 degrees.
> @Jim_R said:
> Isn't the pigtail for the vaporstat suppose to be turned " loop" front to back, another quarter turn or doesn't the expansion/contraction of the 'tail not matter with the non Mercury equipment.. ?
Shouldn’t matter—the pressure switch isn’t affected by minor (or maybe even major) orientation variance.NJ Steam Homeowner.
I bet it doesn’t hit 160 being protected by the water in the loop plus the air cushion above the water. I’ll have to measure mine, I’m curious nowNJ Steam Homeowner.
It may be a little hard to see in the photo, but the black iron section below the union is also a water "trap" and filled with water. It never even get's warm to the touch.
- 120 Geothermal
