Laars ebp 110
vadim
Member Posts: 1
my laars ebp 110 started making weird noises! like a hammer knocking for 5-6 times! i took off the cover and turned it on! sounds start after 20 seconds as it starts to kettle.... and blue sparks ignite
You got a couple possibilities there, it needs cleaning, tuning and maybe a circulator. Go get a good local repair guy, look here under find a contractorTom
Montpelier Vt0 -
Yikes. I was thinking at first that it was a flow issue like a broken circulator but the delayed ignition makes me wonder about a bad inducer too.... either way turn it off and get a service tech out there asap.0
Internal pump and or zone valve stopped working, sounds like you’re flashing steam0
- 120 Geothermal
