Laars ebp 110
vadim
vadim Member Posts: 1
my laars ebp 110 started making weird noises! like a hammer knocking for 5-6 times! i took off the cover and turned it on! sounds start after 20 seconds as it starts to kettle.... and blue sparks ignite
  • Tom_133
    Tom_133 Member Posts: 962
    You got a couple possibilities there, it needs cleaning, tuning and maybe a circulator. Go get a good local repair guy, look here under find a contractor
    Tom
    Montpelier Vt
  • kcopp
    kcopp Member Posts: 4,630
    Yikes. I was thinking at first that it was a flow issue like a broken circulator but the delayed ignition makes me wonder about a bad inducer too.... either way turn it off and get a service tech out there asap.
  • GW
    GW Member Posts: 5,137
    Internal pump and or zone valve stopped working, sounds like you’re flashing steam
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
