Laars ebp 110
vadim
Member Posts: 1
my laars ebp 110 started making weird noises! like a hammer knocking for 5-6 times! i took off the cover and turned it on! sounds start after 20 seconds as it starts to kettle.... and blue sparks ignite
You got a couple possibilities there, it needs cleaning, tuning and maybe a circulator. Go get a good local repair guy, look here under find a contractorTom
Montpelier Vt0 -
Yikes. I was thinking at first that it was a flow issue like a broken circulator but the delayed ignition makes me wonder about a bad inducer too.... either way turn it off and get a service tech out there asap.0
Internal pump and or zone valve stopped working, sounds like you’re flashing steam0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
