Should I upgrade my Thermostat (Lux)?
ImYoungxD
Member Posts: 130
Current thermostat is Lux brand which turns on the heat with differential settings. It's currently on #4 on 68 degrees. It calls for heat at 67 and turns off on 69. I have no issues with it. Thermostat is only used for heating.
Should I upgrade this to Honeywell pro vision to get the 1 cycle per hour? Would I be saving money over the long run?
TIA
TIA
If it's comfortable, I wouldn't change anything.
if fuel usage is excessive, you should start by looking at the system as a whole, to see what the cause is, before starting to make changes.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
