Should I upgrade my Thermostat (Lux)?
Current thermostat is Lux brand which turns on the heat with differential settings. It's currently on #4 on 68 degrees. It calls for heat at 67 and turns off on 69. I have no issues with it. Thermostat is only used for heating.
Should I upgrade this to Honeywell pro vision to get the 1 cycle per hour? Would I be saving money over the long run?
TIA
  • ratio
    ratio Member Posts: 4,176
    If it's comfortable, I wouldn't change anything.
    if fuel usage is excessive, you should start by looking at the system as a whole, to see what the cause is, before starting to make changes.
