Automatic Flue/Vent Damper
This unit no longer works automatically so I have set it to open all the time. I have a one pipe steam system. Will this cause any problems besides a slight increase in heat loss through the flue?
    Jamie Hall Member Posts: 27,312
    No. Just lock the blessed thing open and leave it be. Better yet, assuming that this is oil, have it taken out and install a good barometric damper and have the draught properly adjusted.
