Removing a pipe that in the way
jACNJANE
Member Posts: 1
I bought a house and wanted to remodel Kitchen.The problem was the pipie the heated upstairs bathroom was 5 feet from the wall and next to a stove which we got rid of. I removed the pipe and capped it.Is this alright to do. boiler and heat work like a charm,so I am thinking it was fine. the pipe was a vertical pipe so I didn't see any issues.
jack
jack
A lot more info is needed. Is the system steam or hot water? Some pics would help.Bob Boan
So now there is no heat in the bathroom?All Steamed Up, Inc.
Consulting0 -
no offense but you probably **** up
Located in durham NC.
- 15.8K Strictly Steam
