Carlin electrodes
Rock
Member Posts: 50
in Oil Heating
my electrodes are 8 1/2 inch total length, is this a ES-188n4? If so is there a cross reference number? I cant find them on ebay or amazon. And what tool can i use to set these electrodes?
Thank You
Thank You
Ok Steve, i will leave this to a trained processional and go back to coloring my coloring book0
Good ideal
...processional...lol, perfect!Rock said:Ok Steve, i will leave this to a trained processional and go back to coloring my coloring book
Try to stay inside the lines and maybe it will get put on the refrigerator.
I'm sure you're able to handle the minuscule task without much trouble, especially with a full set of Fischer Price tools kept in a Hello Kitty lunchbox.
What @STEVEusaPA was politely trying to tell you is, if you do this yourself, sure it might work, there will be a flame (maybe). But who is going to do a combustion analysis to make sure everything is SAFE.
It doesn't cost, it pays to have a pro properly adjust the burner and test the limits and safeties on the WHOLE system.
BTW, what are the measurements of the 3 position points needed to set the electrodes? No cheating and checking YouTube.
Keep fiddling and there might be a procession, following you to your dirt nap.0 -
- 120 Geothermal
