Storage tank vs boiler
kevsul1
Member Posts: 28
What is the benefit of having a wall hung boiler that is piped to a storage tank vs one that does it internal in the boiler itself
a more accurate boiler sizing. less short cycling, less boiler ware & tear. more dhw0
Wall hung is less expensive, simpler (less parts to break) and easier to service vs. combi.0
Wall hung boilers usually heat domestic water via indirect water heater (IE tank with coil inside).
I think the other option you are thinking of is a combi boiler?
With the indirect, you can size the boiler to the heating load and use the storage buffer to get you through periods of higher DHW usage."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 167 Indoor-Air Quality
