Hot water heating control...? What is it?
DanBee
Member Posts: 3
I came across this during a site visit to replace a boiler. Residential Open hot water gravity system
the item pictured has Honeywell stamped on it
My guess is that it contains mercury in the bottom section and operates a check valve.
When the return water gets hot enough the mercury would rise and close. When the water would cool down, the mercury would drop and open the valve.
That is the jist of it. Lot's of mercury, so be careful.
Dan has a better explanation in "Classic Hydronics""If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Thanks for the Reply Zman. i remember seeing something similar years ago, I wasn't 100% on it. thanks for confirming.
DB0
