1107-2 Control Not Flashing
EbenS
Member Posts: 4
in Gas Heating
Hi all - have a Weil McLain CGA4 boiler with the 1107-2 IBCM (not to be confused with ICBM). We had an over-voltage event and lost some appliances, the furnace was one of them. I get no lights on the board at all - wondering if this is a good bet to try swapping it out or if there are some diagnostics that I can do prior to buying a new board? When I set the thermostat to heat, the circulating pumps come on, but I get no lights or anything on the furnace at all.
If it wasn't apparent - this is a hot water boiler, natural gas and it circulates through radiators. Thanks!!!0
I expect that that board is toast. If the surge was bad enough to get appliances, it surely was bad enough to get the board.Br. Jamie, osb
Tim - yes, power to the board...0
I think you need a new board.0
- 15.8K Strictly Steam
