Radiant Wall Ideas
KLaugh
Member Posts: 12
I am trying to become informed on designing and installing a Hydronic Radiant system in a new construction house. I have seen it mentioned several times that a radiant wall on posts. I have been studying Modern Hydronic Heating by John Siegenthaler. He shows a way to install a radiant wall and I have no problem understanding that. I am looking for other options on getting the same results.
I saw that @Hotrod had some creative ideas he posted. How creative have you seen? I am looking for ideas that will keep someone from driving nails into heating tubing and stand out.
keeping the tube in the lower 3 feet of wall should keep nails out in the future
Getting sheetrock or wood over the tube will take care
I’ve taken a roll of butcher paper add traced all the tube runs to have a record for future
Infrared cameras like the iphone adapter type are getting very inexpensive to see exactly where each tube and loop end isBob "hot rod" Rohr
I have tubing in some walls that runs vertically. It crosses over thru holes drilled in the center of studs.
If some picture/mirror hanging person is looking for a stud, they could nail thru a tube with the horizontal installation; less chance of it with vertical tubing.
Any nail driver just has to be informed that there is "plumbing" just behind the sheetrock or in the concrete floor.
I now have a FLIR TG165 gun (about $350...much less than the sewing machines we have in the basement BTW
)that shows every tubing loop.
Even buried in concrete floors and below floor tile installed on top of 1 1/4" of wood.
You can also see where your dog was laying 10 minutes ago.0 -
That is not my wall. I was interested in other ways to do a radiant wall. Something like these. Something that is attractive. I think either would be able to mount on a wall. Is this a bad idea?
I did a couple of walls where you put continuous plywood over insulation. You then use strips of plywood and and joist track over snapped over the tubing with the flat part towards the room. The joist track protects the tubing and does a great job transferring the heat.
I have a picture somewhere, just pretty deep in the archives
Albert Einstein1 -
Zehnder makes all sorts of panel rads for ceilings, walls, cabinets, used for heating and cooling if you want a finished, ready to install product.
http://zehnder-rittling.com/downloads/radiant-ceiling-systems/rittling-linear-radiant-ceiling-panels/Bob "hot rod" Rohr
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
