TOO good not to share..
bboepple
Member Posts: 6
A gentleman called the store today needing a new T&P valve to replace the one on a TOYO oil fired WH that was leaking. When I asked for more info he said he would send a photo of the old one, which a "professional" plumber had installed a couple of years ago. This is in a northern Alaskan village. I COULDN'T believe what I saw !!
@Steamhead,
What's your favorite saying??
Apparently the "professional" plumber needs to go back to plumbing school. He also can't read.0 -
What the farfignugal , huh, waa, how is that even possible?? Oh my goodness.0
Hello, It's a god thing it leaked! Otherwise... Hope it's OK to save a copy of the picture? it's just too good to forget.
Yours, Larry0 -
Ridiculous! It even has 'Inlet' stamped on it.
He says a "Pro" installed it but you can't take everyone at their word. A Pro would know better (I think) and being in an Alaskan village, I wouldn't be surprised if he couldn't get someone out there quickly and with the right part????0
Bob Boan
Typical "bush" job. There are some very "interesting" plumbing and heating systems in some of these villages. Most of the time it involves making do with what is available, but at least it is usually put in properly.
I just finished up a job for a customer who spent three years solid working on these bush jobs, and he would tell me stories of the things you had to do to keep things going. Interesting work for sure.
If that picture didn't show a dangerous situation, it would be very funny though.
Rick0 -
Professional only means he got paid to install the valve.
Professional has nothing to do with qualifications, knowledge or ability.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
Had the very same observation a few years ago with a pressure relief valve on a hot water space heating boiler that had been installed by a very reputable mechanical contractor. I turned the boiler off in the dead of winter and called the contractor telling him he needed to get someone there immediately to install the relief valve correctly. The boiler was a "time bomb" waiting to detonate!0
Look on YouTube for the video of the professional boiler installer in Alaska. He does just about everything Dan tells us not to do and he is so proud of his work! I quess there is not alot of competition in Alaska. All the best Jack0
Old one was leaking and he didn't have a pipe cap. Had to make due with what he had........0
All together now.................EBEBRATT-Ed said:@Steamhead,
YOU CAN'T FIX STUPID!!!!!!!!!!!!!!!!!!
Consulting1 -
YOU CAN'T FIX STUPID!!!!!!!!!!!!!!!!!!0 -
nice to know it will open if the outside temp or pressure get too high0
- 116 Geothermal
