Piping Opinion Needed
Distance
Member Posts: 6
Piping above the controls is fine. You're a professional, which means they won't be leaking, right?
But going forward, the dropped header should always be a minimum (better + 1 size) of the steam main. Looks like the steam main is 2-1/2". Ergo, the header should be 2-1/2" or 3".
New England SteamWorks
newenglandsteamworks.com0 -
I might have done it differently but what your doing looks ok. So just to be sure your tying the twp boiler supplies together then feeding the tee, The riser is your supply and the end of the tee becomes your equalizer.
A couple of things. Come out of the tee with a close nipple (or at least a short one) and drop down. Don't go across until you drop. You want the water to fall out of the header, think like a waterfall. If possible make the drop go below the boiler water line before turning
Also can't see from the picture but how many supply mains do you have? It is best to bring all supply mains down to the header individually, but If your header is the right pipe size and as the riser increases your probably ok as is.1 -
.0
.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
