Drab to Fab HVAC
GW
Member Posts: 5,184
this weeks gem; 4 1/2 days of grinding
1
Why didn't you leave the bottom return for the basement unit? Looks like a Carrier came out and may have even fit into the existing supply plenum. Just wondering.0
We had major height issues, the new ahu was taller and the cased hw coil was 10” or so. The slant coil made it possible to have a side return0
Hi Gary
Good looking job. I know this is an old post so I hope you get this comment.
I have the exact same situation as this. I need to replace a 3 ton unit and 2 x 2 ton units. I have the boiler and zone piping and circulators installed. I’m using the exsisting ductwork.
Can you tell me the size of your system and what type of coils you used. Also what do you take into consideration in choosing an Air Handler when installing a heating coil in front of it.
The coil I was looking at required 1700 CFM
Thanks in advance for any help
Brian0 -
Hi Brian, I mainly use Bryant and now Carrier (same basic thing). I downsized a 1/2 ton on each system. I'm a downsize guy, i get my jollies dialing down the BTU's. This is a 1 1/2 (attic) and a 2 (basement). The coils are from carrier, they fit nicely on the ahu's. I'm not sure who actually makes the coils, it may or may not be carrier
When you say 'required 1700 cfm" i don't fully understand. You mean it's 1700 to get its full rated BTU?
I don't check the HH site every day so please email me if you need faster comments, gary@wilsonph.com0 -
Hi Gary
Sent you an email
thanks0
