Navien NHB 80 vs Greenstar 100.
DKBERLIN
Member Posts: 2
I live in central CT currently have a quietside (I know JUNK). I don’t think it will last through this winter so I am in the market for a new gas boiler. I had hard water issues in the past so now I have a softener. Believe it or not but that JUNK lasted me 6 years so maybe I’ll call it junk no caps. However due to all the problems I had with it I have learned a valuable lessons. DO YOUR RESEARCH. So I want to replace the boiler and this time I would also either totally isolate the DHW or run an indirect. I live in a 1700 sqft raised ranch 2001 built. I don’t think I need more than 80k btu. Naviens is really popular here but I read somewhere that it is made in Kore in the same factory as my junk. Bosch... I’m not sure if it’s not over engineered like a VW plus heat exchange is aluminum. Both warranties are pretty similar. There are 2 adults and 1 child so I think I need a 50 gal tank. Can anyone help me make up my mind. I have spent a week searching the web for real reviews but mostly you’ll find horro stories. Not too many people write good reviews. I sure didn’t after my junk failed a number of times. The best reaction was when I called for help last winter and I told a service company what boiler I have. LOL
Look into this unit. Nearly 2 million out there no leakers.
Only 4 moving parts.
I have installed many.
http://www.ibcboiler.com/ibc-products/hc-series/0 -
It looks impressive The only thing is when I had the quiet side installed it to looked impressive however they are not in business any more and I have nowhere to get parts. I’m leaning towards a navien because their costumer service seems on point and the amount of boilers installed and the amount of HVAC pros in the area that would help if a problem arises. Plus the Bosch has an aluminum heat exchange. What about a water heater? Indirect or totally isolated? Can anyone share some knowledge. Maybe preference one?0
If I only had those two choices, I'd recommend the Bosch. If you're really enamored with Navien, then look at the NFB Fire tube model.
The contractor is 98% of the equation. Focus on finding a good hydronics contractor. Go with his recommendation.Bob Boan
What he said! As a contractor, I choose a brand based 20% on the unit itself and 80% based on the support that's available locally. By support I mean a good local rep, STOCKING wholesalers and most importantly, parts availability.Ironman said:If I only had those two choices, I'd recommend the Bosch. If you're really enamored with Navien, then look at the NFB Fire tube model.
To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
