Old zone valves
Steve Minnich
Member Posts: 2,868
Looks like a precursor to the Gold series. Surprised they worked!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
You’re right. 3 wire, heat motor. #2 sharing end switch and motor. I had repaired an internal wire on valve last winter and suggested replacing all of them when I replaced the boilers as a preventative measure. 57 years is quite a run for a zone valve.Steve Minnich0
I guess the wax motor type valve, proved to be very reliable in this case.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
