Old zone valves
Tinman
Member Posts: 2,808
Looks like a precursor to the Gold series. Surprised they worked!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
You’re right. 3 wire, heat motor. #2 sharing end switch and motor. I had repaired an internal wire on valve last winter and suggested replacing all of them when I replaced the boilers as a preventative measure. 57 years is quite a run for a zone valve.Steve Minnich0
I guess the wax motor type valve, proved to be very reliable in this case.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
