Added cost of material vs decrease in time and labor. Yes, No, Maybe?
cnmdesign
Member Posts: 103
Dropping the loop end under the joist.
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
Never heard that. The manufacturers do provide guidelines for where holes can go-size, amount, how far from top/bottom chord and how close to the end.Big Ed said:What I understand you can't drill through those laminated joists by the manufacture
@Big Ed
Here is a typical manual http://www.bc.com/content/uploads/bc-resources/west_spec_complete.pdf
You can drill hole up to 1 1/2" anywhere in the joist as long as you maintain 3" between them. For bigger holes you need to refer to the chart."If you can't explain it simply, you don't understand it well enough"
Albert Einstein-1 -
I use a hole saw with angle head drill.
I drill about half way thru one side and do the other side.
With practice you know when to stop on the second drilling and can knock the plug out of the joist.
This avoids wedging the plug into the hole saw.
Most of these joists come with pre punched KO's, but are seldom lined up for straight runs.
The large holes are not allowed near the ends as there may be a load bearing wall above and that is the "crush" zone of these.-1 -
Except Bearing Zones!Zman said:@Big Ed
-1 -
Most all the TJI type, plywood web joists have 1-1/2" pre-punched holes every 12". The holes can be over bearing walls sometimes. But use the manufacturers "Drilling Guides" to be sure.pecmsg said:
The main thing is having the framer line up all the pre punched holes on either top or bottom.
When that happens plumbing and wiring is a cinch, a ballpeen hammer or pipe will pop out those supplied holes.
Web stiffeners should also be used at bearing points, but that rarely happens around here.
Plastic pipe insulators fit in those holes also.
GlueLams or ParalLam are different than TJI joists and have much different drilling limitations.
Living the hydronic dream-1
- 19 Recall Announcements
