Indirect Tanks and proper Pumping
Pwall
Member Posts: 19
Quick easy pumping question.
I have a Utica H20 40 gal indirect water heater. It's currently being fed by a Taco 007 ECM pump from a Utica Trifire Boiler 4075. This circulator is dedicated to the DHW tank.
There are 2 other zones but they have their own circulator and the DHW has priority.
The documentation I can find on the tank indicates the ideal flow would be 14 gpm at 5.7 ft head.
Those flow requirements are a bit over what that pump is capable of. It's probably flowing around 12 gpm or maybe around 11 for that head.
Should the pump be ok even though it's a bit under powered or should I look at something more powerful even though at those performance specs it gets pretty pricey?
Or possibly parallel pipe 2 small cheaper 005 size pumps to split the gpm requirements?
The 007 will work just fine. In order to get the max capacity out of the indirect, the boiler would need to about 50% larger. Moving the water a little faster will have little or no impact on the performance of the system."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
