Fusible Link Valve
bean
Member Posts: 34
in Oil Heating
What is a Fusible Link Valve? How does it operate?
Any of a variety of valves, usually for oil but sometimes for gas which contains a fusible link and a spring. The fusible link is a low melting point alloy, chosen to melt at a certain temperature, depending on the application. The link is arranged -- in the variety I suspect you are enquiring about -- so that it holds a valve in the oil line open against the force of a spring. If the temperature gets too high, the link melts and the spring shuts the valve.Br. Jamie, osb
Which one specifically are you talking about? There is suppose to be one (typically called a firomatic) at the burner and one at the oil tank, for the oil lines, and there should be one above the heating appliance in series electrically with the main shut-off to the system (burner).
- 120 Geothermal
