Bosch Greenstar
Harvey Ramer
Member Posts: 2,239
With the crc100 control, do you also need ODR?
I believe the CRC200 can work with outdoor sensor but not the 100?To learn more about this professional, click here to visit their ad in Find A Contractor.1
No, it uses the indoor temp only. It raises or lowers the water temp based on the temp difference between the room setpoint and the actual room temperature. It is a constant circulation control. With the CRC 200, it uses the outdoor sensor ONLY for warm weather shut down. That feature isn't in the CRC 100.1
Thanks! I was thinking that's the case but I couldn't find any difinitive information.
Indoor reset rocks on a single zone system. It's better than outdoor reset in that application.2
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
