Control identification...
KCA_2
Member Posts: 308
Does anybody know what this is? Need to see if I can find a replacement...
I know it's a motor control for a tempering valve with outside reset technology but I need manufacturer and maybe a model number....
Thanks a lot
:-)) Ken
:-) Ken
looks like a Danfoss or Esbe maybe. A few manufacturers offered a similar product, Heatlink, Watts as a 3 or 4 port mix valve actuator. CE is a common listing on European products. Sometimes the brand of tubing on the job can be a clue to the controls used.Bob "hot rod" Rohr
Thanks HR.... the system is a remodel over a remodel over owner installed per tubing... would seeing a pic of the valve help? No markings on it....:-) Ken0
I think it was called AutoMix 20. This might be a newer version.
https://www.c-o-k.ru/library/instructions/vexve/avtomatika-regulyatory-moduli-termostaty/9048/25939.pdf
Start with Danfoss maybe?
I'm sure you could find another actuator to fit the valve, but it might need a tekmar to control it like that one.,
Yeah.... This unit has a reset integrated. There are other technologies out there that require a separate control.:-) Ken0
The automix – 20 Is an interesting valve but it doesn’t have outside recess. So that probably isn’t the one however it could be an automix 13. LOL:-) Ken0
Maybe? There were different versions over the years , and some OEM versions also.Bob "hot rod" Rohr
The control is probably from WSE, they used the basic ESBE actuator and enclosure but added reset. If that is the product, Paxton Controls used to import them. A standard ESBE actuator with separate reset control should be able to replace it if on an ESBE valve.0
WSE? Can’t find it....:-) Ken0
Try Paxton. Used to be a knowledgable fellow there, Leif I think. He would know if you send him a better pic.
https://www.paxtoncorp.com/actuators.php#Bob "hot rod" Rohr
Thanks.... but that's the only one I have....:-) Ken0
If it's a ESBE, here are my notes:
TC62 actuator w/ outdoor reset
V3R 3-way mixing valve
V4R 4-way mixing valve
VM62 actuator only8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Hi KCA, my buddy sent me this post. I sent you a private message. My email is there. I can email you a copy of the manual.
Best,
Paxton Corp0 -
Hello Paxton. I did get your email and I thought I responded to you but I haven’t heard back from you. I would love to get the manual and maybe even a place where I could find a replacement.
Thank you very much
:-)) Ken:-) Ken0 -
Ken, did you resppond through the messenger on this site, or to his e-mail directly? Some times the messenger does not connect. It could be a setting on their end for spam?KCA said:Hello Paxton. I did get your email and I thought I responded to you but I haven’t heard back from you. I would love to get the manual and maybe even a place where I could find a replacement.
Thank you very much
:-)) Ken
We actually communicated through his email and then all of a sudden communication stopped. So I’m not sure what happened.:-) Ken0
Hi Ken,
Spam filters buried your later emails. I thought "no news was good news" and that I sent the cut sheet. I emailed it again a few minutes ago. Feel free to call us. Our number is on our website.
Best,
Paxton0 -
Ha! Technology!
Thanks very much Paxton......:-) Ken0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
