natural gas / spa
Snowmelt
Member Posts: 1,428
not steam or boiler related, my wife wants a spa for back yard. All I see are electric spa any suggestions we went a 6 seat spa.
Spas are, in my mind, pretty disposable. They all have different features but, in the end, you are doing well to get 5-10 years out of one.
It has been a few years but you used to be able to order them without an electric heater so you could run off a heat exchanger from a hydronic source."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
And a "break on rise" aquastat with manual reset and a solenoid valve wouldn't be a bad idea so we won't have to come over and add carrots and potatoes.0
how far from the boiler? Those super insulated electric versions are fairly economical to run, 25- 30 a month. Check some of the online calculators.Bob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
